Hello everyone, is there any method with which I can write different data in different Excel rows?
I have a list (List 1) with the numbers of the Excel rows in which I want to enter my data in the same order (List 2).
The problem is that the node I know (Excel write to file) indicates only the row with which the process starts, but in my case they are not consecutive numbers of rows.
Do you know of any node with which this can be solved?
Infinite thanks.
Try adding A series of empty lists equal to the difference between the two row values.
Why not to write all the row in the column?
You can manage a way to first read the column from the excel, then processing data so to change the interested cells and write back to excel.
