Error With API Method NewFamilyInstance
Hi all!
I am trying to create beams at the location of walls getting the wall location for the lines.
Trying to use the NewFamilyInstance with the lines, familySymbol (I tried extracting symbol from beam in project as well as inputing familytype), level, and structural framing type - I am getting the following error:
no method matches arguments for NewFamilyInstance: autodesk.revit.db.line, autodesk.revit.db.familysymbol, autodesk.revit.db.level, revit.elements.familytype.
Is there a way around this?
Using the BeamsByCurve node the beams do work, though I would like to solve it through the custom api script.
import sys
clr.AddReference('RevitAPI')
app = uiapp.Application
dynCurves = IN[0] if isinstance(IN[0],list) else [IN[0]]
famSymb = UnwrapElement(IN[1])
level = UnwrapElement(IN[2])[0]
structType = IN[3]
revBeams = []
dynBeams = []
#Begin transaction
try:
    for curv in dynCurves:
        revCurv = curv.ToRevitType()
        if not famSymb.IsActive:
            famSymb.Activate()
        newFam = doc.Create.NewFamilyInstance(revCurv,famSymb, level, structType)
        revBeams.append(newFam)
        dynBeams.append(newFam.ToProtoType())
#End transaction
finally:
    TransactionManager.Instance.TransactionTaskDone
OUT = dynBeams,revBeams
Hi @zviLNBRQ ,
Welcome to the community.
This is where you are missing on the inputs, here instead of this just replace it with the line below:
newFam = doc.Create.NewFamilyInstance(revCurv,famSymb, level, StructuralType.Beam )
As NewFamilyInstance Method (Curve, FamilySymbol, Level, StructuralType) this is the method you are using and here it’s asking for StructuralType and that is an enumeration not the FamilyType.
Happy Coding,
BM
Thank you and thanks for the reply.
Is it it expecting StructuralType.Beam as a string?
Just Make sure to import Autodesk.Revit.DB.Structure Namespace as above coz the particular enumeration is coming from Structure Namespace so it won’t be a string.
