Hi all!
I am trying to split a beam by creating new beams at the points using NewFamilyInstance. For some reason it isn’t working and doesn’t give any particular error.
Would appreciate if someone can help figure this out! ![]()
import sys
import System
from System import Array
clr.AddReference('RevitAPI')
app = uiapp.Application
elems = UnwrapElement(IN[0]) if isinstance(UnwrapElement(IN[0]),list) else [UnwrapElement(IN[0])]
parameters = IN[1]
lvl = UnwrapElement(IN[2])
strType = UnwrapElement(IN[3])
beam = elems[0]
#Get beam symbol
symbol = beam.Symbol
#Begin transaction
try:
#Get beam curve and start/end points
beamCurve = beam.Location.Curve
point1 = beamCurve.GetEndPoint(0)
point2 = beamCurve.GetEndPoint(1)
#Create points at parameters
points = [beamCurve.Evaluate(p,True) for p in parameters]
#Drop first and last points
splitPoints = points[1:-1]
#define start point of first beam
startPoint = point1
beams = []
dynBeams = []
for point in splitPoints:
#create line with start and end points
line = Line.CreateBound(startPoint,point)
beam = doc.Create.NewFamilyInstance(line,symbol,lvl,strType)
beams.append(beam)
#####dynBeams.append(beam.ToDSType())
startPoint = point
#Create last beam
line = Line.CreateBound(startPoint,point2)
beams.append(beam)
#End transaction
finally:
OUT = beams
