StructuralFraming.BeamByCurve in Python Node
Hi All,
I get this error
TypeError: expected FamilyType, got FamilySymbol
if I try to use StructuralFraming.BeamByCurve inside a Python Node.
I’m using the same code inside th All Family Types Of Category (Clockwork)
Any Idea why?
import System
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
# Import RevitAPI
clr.AddReference("RevitAPI")
Curves=IN[0]
Lvl=IN[1]
cat=Revit.Elements.Category.ByName("OST_StructuralFraming")
Beams,OUT=[],[]
collector = FilteredElementCollector(doc).OfClass(FamilySymbol)
bic = System.Enum.ToObject(BuiltInCategory,cat.Id)
collector.OfCategory(bic)
Beams.append(collector.ToElements())
#OUT=Beams
for curve in Curves:
	beam=Revit.Elements.StructuralFraming.BeamByCurve(curve,Lvl,Beams[0][5])
	#beam=Revit.Elements.StructuralFraming.BeamByCurve(curve,Lvl,IN[2])
	OUT.append(beam)
You’re calling a method from Dynamo’s Revit wrapper class which expects a FamilyType (a wrapped Family Symbol). Try calling .ToDSType(True) on the FamilySymbol to wrap it and see if that works. I would also improve the FilteredElemsntCollector so it finds and returns the specific FamilySymbol, rather than indexing blindly since it’s likely to return an unreliable result if the order of objects change or if new types are added to the project.
Thanks @Thomas_Mahon!
