Error when trying to cut solid by planes while using dynamo
01.02. Cut Solid by Plane (Points Z+).dyn (25.4 KB)
Hi guys,
I’m trying to cut Solid 3d by plane using z Plane and point from excel. But for some reason, some planes don’t work correctly returning the same solid without a cut.
I tried to identify the problem but dynamo does not return any warning.
All responses will be helpful
PD I attach dynamo node and link of solid 3D in civil 3d
Hello @equispea
Your script refers to the Excel file. Can you share there?
Maybe I’ll find the solution…
thanks,
this is the xlm file :Points Z+.xlsx (10.2 KB)
Change Level :
Your script is OK.
Except it takes hours to finalize the task.
hey, Georges, could you please explain from where did you get the Solid.SlicebyPlane node ?
Hello Hassan,
Thanks for prompt reply. I could not find Autocad Package. From which package you got this node ?
No need to install AutoCAD package.
It is already in Dynamo for Civil 3d.
My bad, I was looking for this node in Revit. I wish they had similar node in Revit Dynamo. Thanks anyway
For those who are searching for similar Node in Revit, you could use Geometery.Intersect.
