I just wanted to get started with Dynamo for Civil 3D and everything I make or even the sample scrypts do not run. I get an error, please see attached picture.
Does anybody have an idea what it could be?
Dynamo for Civil is up to date and I even tried reistallation.
Dynamo for Revit works properly.
In Manage next to Dynamo I have âRun Scriptâ - not dynamo player like in Revit. If I hit that and select the scrypt, no extra window will open but it says scrypt is running successfully. No warning or fatal error. I used one sample scrypt (Civil3D_SplitCorridorSolid) and it did not work, but I got no warning. Maybe it did not work because I need to work on the scrypt and change more then just the name of the corridor. A very simple Scrypt I created - Line by coordinates, worked fine. Could also save the file, without fatal error (which was the case before).
I can launch Dynamo with that command. Launching was never an issue. I can work on dynamo but when I hit run I get the warning I showed in my first post.
Please let me know if you need additional informations.
Hi
Dynamo has been released with version update 2. Would you please have a try to install the update from Autodesk Desktop App and check if it will work fine? (Dynamo Player will be shown :D)
Hi Albano,
Would you help to check if you have Assemble.Publisher.AutoCAD installed on your machine? If so, could you change the bundle folder name and restart C3D to try again? You may find the bundle as: âC:\ProgramData\Autodesk\ApplicationPlugins\Assemble AutoCAD 2016 to 2020 Plugin.bundleâ.
We are still working to dig the root cause. Hope this can help you to workaround it in temporally.
