Civil crashes while running a Python Script Node from Dynamo Player (Civil3D)
Hi! I’ve recently updated my Civil to the 2025 version and began updating my company’s routines from the previous versions to match the new nodes and packages, but I’m facing an unexpected problem.
I don’t know exactly why, but I can’t make my Python Script Nodes work on Dynamo Player. They do work on Dynamo Editor as expected, but if I try to run an empty script with only a template python node and an input, it freezes.
The worst part is that I can’t even finish the process, I need to restart my computer in order to use any instance of civil properly.
I noticed that it isn’t happening on my colleagues’ computers, or at least the ones I’ve tested (technically the same setup and the same version of the software, installed on the same day).
So my take is that it might be related to some kind of lack permission or a problem during the installation of the software. Have you guys faced something simillar in the past?
