Hi guys,
I have installed the latest stable build, but when i create a point and hit run i get the folowing message:
“Warning: Point.ByCoordinates operation failed.The type initializer for ‘Autodesk.LibG.LibGPINVOKE’ threw an exception.”
I need to install some additional software ?
Vlad P.
i have done some debug and i have found that Dynamo is looking for revit only in program files(my revit is installed on other drive). I have moved revit in programfiles\autodesk and the problem was solved.
Hello Vlad Pavel,
Sorry for in inconvenience and I am glad that you found the root cause and resolved that.
We will come up with better solution to this problem.
Thanks for reporting.
Keep using Dynamo!
Thanks,
Ritesh
I have the same issue, but I cant install Revit on C: (not enought space on my little SSD)
So I search a solution and I found it : a Simbolic Link
I made a “Revit 2015” SimLink of the “D:[apps]\Revit 2015” directory (installation path of my Revit) in the “C:\Program Files\Autodesk” (standard path of Revit on my 64bit Win 7) and all is OK !
