Error: un-/hide CAD files with archi-lab node
Hi everyone,
@Kulkul asked me to open a new topic for my issue posted in:
Hide all lines of a specific line style / texts of a specific text type
Most part of the graph is without function. For problem solving I have tried to keep it simple. So I have the CAD element, the current view and the node but the node give me an error:
The set of elements to be hidden is empty
Any advice?
Hi @Leo_Hart
Your currently passing string values to VIEW.HIDEELEMENTS node you need to connect elements to it.
@Kulkul thanks for your respond. But I think this is not the case:
Ok guys, I figured it out.
You must pass more than two different elements to the node.
:edit:
Revision: I think I am not quite right…
If I select the element with the [Select Model Elements] node it is working.
The difference is that the select node select an [import.Instance] and not an CADLink Element
If you pass an Import.Instace element it is working fine, but it in my opinion it is a bit hard to handle with it.
