Hi all,
One of my scripts give an error in Revit 2022 with Dynamo version 2.12.0.5650.
Does anyone know how to fix this problem or is there an alternative node or python code?
Warning: Tools.SplitPipeByPoints operation failed.
Method not gevonden: Autodesk.Revit.DB.FormatOptions Autodesk.Revit.DB.Units.GetFormatOptions(Autodesk.Revit.DB.UnitType).
Hi @jw.vanasselt,
You can use the Split ByPoints node of the Genius Loci package instead.
That’s amazing, my script will be a lot more faster!
I can delete alot of extra nodes by this one.
Thanks!
Is there a maximum to split?
I want to do it multiple times in 1 pipe/duct:
Is this a lacing / level problem?
Thank you very much!
It’s the transpose / cycle who did it!
Hi @jw.vanasselt, I’m having the same problem, can you show me the solution?
Hi @igor.guilherme ,
Over here an example:
The levels in the nodes depends on the structure.
Thank you very much @jw.vanasselt !
Do you have a file numbering the location of the splitted ducts?
