Error reading dynamo on excel
this should solve your problem:
Furthermore you need to adjust this part of your path:
I made your code,
I just succeeded to understand it, so I don’t need my excel list anymore, you create it directly with dynamo in the code block
1…22…1;
I can transform this block code as a string so that it is an input ? so that before launching the dynamo I can tell it the exact number of lines by defining the string as an input
Depents what you want. If your excel list gets longer, than it will still work. Otherwise you would need to adjust the list in dynamo
yes, I have to adapt but I can insert a number in block before launching it
I just need to transform the block code into a number ?
I have my space named 2 times if I have twice PO1 in a space I will look at I think in my base code it was displayed once even if I had two
You could use a number node as input and then a custom node 1..NumberNodeOuput..1
Thank you very much for your time!
