I wanted to know how you deal with the problem of reading on dynamo,
Explanation of the dynamo:
I create a list on excel
PO1…PO2…PO3…PO11
With dynamo I make a search of this excel list, to have the families associated to this parameter.
Then I display the spaces with the families which have this parameter in an excel column.
My problem, if dynamo search the families containing PO1 in a space, I will also have the spaces of PO11…PO12…PO13…PO14
which is logical because PO1 is inside, I would like it to read the whole parameter before doing something…
Do you have an idea
It would help if you could provide pictures of your excel file and of your current dynamo path/code
Yes its better like that @leonard.moelders ^^
Step 1
create list
Step 2
Dynamo code
Step 3
Read my Revit
Step 4
Write on excel
Problem in Space 5 i dont have PO1 but i have PO11
Not a video, a picture. Zoom as far in that you can see the input names of the nodes. Open the result preview for every node and then use the screenshot tool from dynamo. You do not need to see all of your code. It will capture the whole workspace by itself:
ahh right, thanks I didn’t know @leonard.moelders
The names of the nodes are missing
Not the group name, the node names.
Thank you
I will have a look
Why doesn’t he do it directly… ^^ sorry I’m struggling but I’ll remember it
I have two goals for this code,
Just a quick question:
The following list shows what you want, right? Until there everything is correct? I ask because your image above picturing the spaces is so bad, that I can’t read the PO numbers in it
yes this list shows me what I want without confusing PO1 and PO11
I didn’t understand this part? “I ask because your image above representing the spaces is so bad I can’t read the command numbers in it
The resolution of the picture is not high enough to read the numbers.
This picture:
its better like that ? @leonard.moelders ^^
Can’t see any difference on the picture, but this is what i got:
I’m going to try to do what you did and test to see if I can keep up with you
ca you show me , what is hidden here pls
@leonard.moelders
and here i can’t see ^^ all
