Error in dynamo 11111
Point.ByCoordinates operation failed.
X
Could not load file or assembly 'file:///C: \Users\VIKRAM\Downloads
\DynamoCoreRuntime? 16.0 (1)
\LibG.ProtoInterface.dll’ or one of its dependencies. The system cannot find the file specified.
facing these problems in dynamo while adding any command in dynamo
You’ll need to install the latest update to Revit, AutoCAD, or similar core products 2023 to get access to the geometry kernel with that version of Dynamo. For older builds of Dynamo you can utilize older core products (ie: Revit 2021).
thanks for your answer. I will chack same
