I tried a new approach and now it works fine. I used the CreateFromCurvesAndShape() method instead of CreateFromCurves() to create the rebar, and ComputeDrivingCurves() method to get the curve of each Rebar.
Still if someone figures out why the first version did not work or if you have suggestions how to improve this script I am open to any advice.
# Enable Python support and load DesignScript library
# Import RevitAPI
from Autodesk.Revit.DB.Structure import Rebar, RebarContainerType, RebarContainer, RebarShape, RebarBarType, RebarHookType, RebarLayoutRule
from Autodesk.Revit.DB import LocationPoint, XYZ, FilteredElementCollector, ElementFilter
container = UnwrapElement(IN[0])
# Place your code below this line
# List of Rebars
rebars = []
# List of errors
errors = []
# Start transaction
for containerItem in container:
# Get the RebarShape of the current containerItem
rebarShape = doc.GetElement(containerItem.RebarShapeId)
# Get the RebarBarType of the current containerItem
barType = doc.GetElement(containerItem.BarTypeId)
# Get the RebarHookType at the start of the current containerItem
hookTypeStart = None;
if containerItem.GetHookTypeId(0).IntegerValue > 0:
hookTypeStart = doc.GetElement(containerItem.GetHookTypeId(0))
# Get the RebarHookType at the end of the current containerItem
hookTypeEnd = None;
hookTypeEnd = doc.GetElement(containerItem.GetHookTypeId(1))
# Get the host of the RebarContainer
element = doc.GetElement(container.GetHostId())
# Get the Normal of the containerItem
norm = containerItem.Normal
# Get the curves of the current
curves = containerItem.ComputeDrivingCurves()
# Get the HookOrientation at the start of the containerItem
hookOrientationStart = containerItem.GetHookOrientation(0)
# Get the HookOrientation at the end of the containerItem
hookOrientationEnd = containerItem.GetHookOrientation(1)
# Try to create the Rebar
try:
# Create Rebar using CreateFromCurvesAndShape method
rebar = Rebar.CreateFromCurvesAndShape(doc, rebarShape, barType, hookTypeStart, hookTypeEnd, element, norm, curves, hookOrientationStart, hookOrientationEnd)
# Check what is the LayoutRule of the current containerItem
if containerItem.LayoutRule == RebarLayoutRule.FixedNumber:
# Set the layout of the Rebar as fixed number
rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber(containerItem.NumberOfBarPositions, containerItem.ArrayLength, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
elif containerItem.LayoutRule == RebarLayoutRule.MaximumSpacing:
# Set the layout of the Rebar as maximum spacing
rebar.GetShapeDrivenAccessor().SetLayoutAsMaximumSpacing(containerItem.MaxSpacing, containerItem.ArrayLength, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
elif containerItem.LayoutRule == RebarLayoutRule.NumberWithSpacing:
# Set the layout of the Rebar as number with spacing
rebar.GetShapeDrivenAccessor().SetLayoutAsNumberWithSpacing(containerItem.NumberOfBarPositions, containerItem.MaxSpacing, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
elif containerItem.LayoutRule == RebarLayoutRule.MinimumClearSpacing:
# Set the layout of the Rebar as minimum clear spacing
rebar.GetShapeDrivenAccessor().SetLayoutAsMinimumClearSpacing(containerItem.MaxSpacing, containerItem.ArrayLength, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
# If no LayoutRule do nothing
pass
# Add the new Rebar to the rebars list
rebars.append(rebar)
# Catch error if unable to create the Rebar
except Exception as inst:
# Add error to the errors list
errors.append(inst)
# End transaction
# Output list containing a sublist of Rebars and a sublist of errors
output = []
output.append(rebars)
output.append(errors)
OUT = output
