Hello, I have to inform all of you that I’m rather new to Dynamo but I’m trying to learn as much as I can right now. Currently, I have to do graduation project about calculating head loss in pipe using Dynamo to transfer data between Revit and Excel. The part that I’m stuck with is how to make ‘table: Allowance for friction loss in valves and threaded fitting’ in Dynamo and transfer the data back to the schedule in Revit.
so I tried to use a condition in code block but there’s a problem as state in this topic’s title
I’m not really too sure either if my code is the right one for this.
I imagine thing to go like this: If I have 4 inch pipe fitting then the parameter ‘Equivalent Length’ will store the data ‘14’ inside.
Thank you for your reply
