Hello everyone, I am trying to create simple truss on RSA by using API. I managed to do basically everything except Defining the list of objects to which load will be applied. In this step I am getting error even though I am doing same thing that tutorial document shows. Any idea how can I solve this problem ?
What is the error?
I have found that a zero touch node written in C# is a more effective way of interacting with the Robot API due to the API being written for COM.
I can create a load case and set value to that case as you can see in the picture. But when I try to choose the node which load will be applied, I got error. In documentation it says I should use “case11.Objects.FromText(“1”)” this line for this purpose but I am having trouble in this line.
Here is the example of my code :
# Load the RSA API library
clr.AddReference(r'D:\Programs\Autodesk\Revit2024\Robot Structural Analysis Professional 2024\Exe\interop.RobotOM.dll')
# Import the RSA API
from RobotOM import *
from System import Object
RobApp= RobotApplicationClass()
# Initialize the Robot application
RobApp.Project.Structure.Nodes.Create(1,0,0,0)
RobApp.Project.Structure.Nodes.Create(2,10,0,0)
RobApp.Project.Structure.Nodes.Create(3,0,0,10)
RobApp.Project.Structure.Nodes.Create(4,10,0,10)
RobApp.Project.Structure.Nodes.Create(5,20,0,10)
RobApp.Project.Structure.Nodes.Create(6,20,0,0)
RobApp.Project.Structure.Bars.Create(1,1,2)
RobApp.Project.Structure.Bars.Create(2,3,4)
RobApp.Project.Structure.Bars.Create(3,4,5)
RobApp.Project.Structure.Bars.Create(4,2,4)
RobApp.Project.Structure.Bars.Create(5,2,6)
RobApp.Project.Structure.Bars.Create(6,5,6)
RobApp.Project.Structure.Bars.Create(7,1,4)
RobApp.Project.Structure.Bars.Create(8,2,3)
RobApp.Project.Structure.Bars.Create(9,4,6)
RobApp.Project.Structure.Bars.Create(10,2,5)
# Retrieve a node and set its label
# with the 'SetLabel' method.
set_node1 = RobApp.Project.Structure.Nodes.Get(1)
set_node2 = RobApp.Project.Structure.Nodes.Get(3)
# Cast the COM object to the specific interface type
support1= IRobotNode(set_node1)
support2= IRobotNode(set_node2)
# Now you can call the 'SetLabel' method
support1.SetLabel(IRobotLabelType.I_LT_SUPPORT, "Fixed")
support2.SetLabel(IRobotLabelType.I_LT_SUPPORT, "Pinned")
# Create a new simple case
case_number = RobApp.Project.Structure.Cases.FreeNumber
cas = RobApp.Project.Structure.Cases.CreateSimple(case_number,"Case_1", IRobotCaseNature.I_CN_PERMANENT , IRobotCaseAnalizeType.I_CAT_STATIC_NONLINEAR)
case1=cas.Records.Create(IRobotLoadRecordType.I_LRT_NODE_FORCE)
case11=RobotLoadRecord(case1)
case11.SetValue(IRobotNodeForceInPointRecordValues.I_NFIPRV_FZ , 3000)
print(dir(case11))
case11.Objects.FromText("1")
Result of my print command is :
['GetValue', 'SetValue', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__iter__', '__le__', '__lt__', '__module__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'get_Objects', 'get_Type']
The error I get is :
Best to ask on the robot product forum for API issues, but my guess is you need to use get_Objects due to the Python interpretation of the C# api.
Again, Python implementation of COM APIs is very limiting and I recommend using C# and a zero touch node setup instead.
You are not the only one with this problem.
I tried your script and ran into the same problem, see also my topics with my username here and on the RSA forum.
What i think is happening is that if i click in the API documentation to Objects, you and up in the area of selection.
This is a short part of a script that select nodes, maybe we can go from here?
SelectionNodes = structure.Selections.Get(IRobotObjectType.I_OT_NODE)
SelectionNodes.FromText(str(allnodes[j]))
structure.Labels.Get(IRobotLabelType.I_LT_SUPPORT,supportlabel2)
structure.Nodes.SetLabel(SelectionNodes,IRobotLabelType.I_LT_SUPPORT,supportlabel2)
Hope you will find this usefull
Or maybe @JacquesGaudin now how to use the selected nodes to apply the load to.
Gr Edward
thanks for your answer.
@gwizdzm @jacob.small can you share us insight in this if it’s goiing to be solved from the autodesk side or structural analysis package part.
I would really like to know?
other information in this topic
the suggested option does not work.
Hope to hear from the team soon
Gr Edward
@ugur_yavan_61
can you share the tutorial where you are talking about?
99.9% sure Dynamo does not have its own own Python - feel free to compare the checksum of the included binaries in GitHub to those of the Python foundation releases.
I am not sure what Jacques saw that indicated otherwise to him.
