Hi there, I wrote a guide for my colleagues to help them setup dynamo in Robot 2023 and navigate the documentation; I thought it was worth sharing it with the community!
Dynamo Setup
The latest versions of Dynamo (2.13) ships with CPython 3 as the default interpreter;
unfortunately, this version doesn’t work well with the RSA API, which is a COM API (as opposed to the .NET APIs of the other Autodesk apps).
Until this is solved (it may take a very long time), you need to install the DynamoIronPython2.7
package and switch your python scripts to IronPython2
interpreter:
Python scripts template
After creating a new python script node, replace the contents with the following code:
import sys
clr.AddReferenceToFileAndPath(
r"C:\Program Files\Autodesk\Robot Structural Analysis Professional 2023\Exe\Interop.RobotOM.dll"
from RobotOM import RobotApplicationClass
app = RobotApplicationClass()
NOTE: the path at the third line may change depending on your installation location and RSA version.
you can then use the app
object to access the objects of the application:
project = app.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
TIP: You don’t need to copy these lines if you don’t need them.
For example, if you only need the load cases, you can use the one-linerloads = app.Project.Structure.Cases
SDK Documentation
The SDK homepage found at C:\Program Files\Autodesk\Robot Structural Analysis Professional 2023\SDK\ROBOTSDK.html
is a good place to start learning the Robot API.
- Getting Started PDF: pages 6 to 19 (8 to 21 of the PDF reader);
- Tutorial of Robot API: very useful, you can start from this and ignore the Getting Started PDF.
Ignore the “The first program” section, since we already set up the RobotOM library with the code in the previous section; see the section below to translate the code; - User guide: once you get how robot API works, this is the reference to find all the objects, methods and properties available.
Instead of using the PDF, check out the same content in windows help format fromC:\Program Files\Autodesk\Robot Structural Analysis Professional 2023\SDK\Robot API.chm
, that is easier to navigate around.
Translating the sample code
The sample code in the SDK documentation is written in Visual Basic or other languages (C++, C#), so it needs to be translated to python.
These are some things to know to convert VB code to Python:
You don’t need to declare variables, so you can skip the rows that starts with
Dim
You don’t need to type
Set
before variable assignment; -
There’s no concept of constants, they are all variables;
Python best practices tell us to use uppercase names with undescores between words, soConst constname = "Hello"
becomesCONST_NAME = "Hello"
To create a new instance of a class, instead of using
variable = New ClassName
you usevariable = ClassName()
(this is what we did withapp = RobotApplicationClass()
above); -
You don’t need to free the object variables, so you can skip the
Set variable = Nothing
lines; -
Methods must always be called with parenthesis, even if they don’t have parameters.
Sometimes you’ll encounter Visual Basic code like this:app.Project.Open filepath app.Project.CalcEngine.Calculate app.Project.SaveAs newfilename app.Project.Close
Python equivalent:
# we store the project variable to save a few CPU cycles and keystrokes prj = app.Project prj.Open(file_path) prj.CalcEngine.Calculate() prj.SaveAs(new_file_name) prj.Close()
Loops: instead of
Dim i as Integer For i = 1 to bar_col.Count Set bar = bar_col.Get(i) ' Do something with bar... Next
You use the
range
function to have the sequence of indices:for i in range(bar_col.Count): bar = bar_col.Get(i+1) # Do something with bar...
Notice the colon at the end of the
for
line and the indentation after it - everything that has to be executed in the loop must be indented by the same amount (4) of spaces.NOTE: If the collection of object allows it (= it doesn’t need the
Get(index)
method to get an element), you can directly get the objects withfor bar in bar_col: # Do something with bar
If statements:
If <condition> Then... End If
becomesif <condition>:
and the code to execute if the condition is verified mus be indented by 4 spacesIf c.Count > 0 Then 'Do things here... End If
if c.Count > 0: # Do things here...
You can’t use the
With object ... End With
construct, so you must specifyobject
in every line of theWith
block:With str.Nodes .Create 1, 0, 0, 0 .Create 2, 3, 0, 0 '... End With
becomes (notice the parethesis added around the methods parameters)
nodes = str.Nodes nodes.Create(1, 0, 0, 0) nodes.Create(2, 3, 0, 0) # ...
The
_
charachter in VB is a line continuation, so that you can split a long line of code into multiple lines;
In python there’s you can use\
, but you don’t need it if you are inside parenthesis (see the code below); -
Enums must be imported and used with their full name (see the code below);
Alternatively, you can look at the User guide for the corresponding integer value and use them instead;
Select Case: there’s no equivalent in IronPython 2. You need to turn it into a series of
if... elif... elif...
to test the various cases
Take a look here for more info about converting VBA code to Python.
Dynamo Forum
There are some (few) examples of python scripts in the RSA section of Dynamo BIM forum, but they try to load the required RobotOM library from an old, non-existent path.
You need to replace the beginning of the code with the one illustrated in the Python scripts template section.
Library imports
Many python examples in the Dynamo Forum use the from LibraryName import *
instruction to be able to access all the object of that Library.
This is strongly discouraged by the Python Community in general, since it can result in strange behaviors.
If you need objects from the RobotOM library other than the already imported RobotApplicationClass
, just import them explicitly with another from RobotOM import <ObjectType>
line.
import sys
from RobotOM import IRobotCombinationType
from RobotOM import IRobotCaseNature
from RobotOM import IRobotCaseAnalizeType
combination = loads.CreateCombination(
1,
"C1",
IRobotCombinationType.I_CBT_ULS,
IRobotCaseNature.I_CN_PERMANENT,
IRobotCaseAnalizeType.I_CAT_COMB
