Am I missing something? List item 32 in && inputs are both true but comes out false.
please show more nodes before the nodes Not and Transpose
I thought the Levels could be a problem for the && node but that should not be a problem
I can show you more if you would like. && should read true though right? I am not crazy?
It is a level problem
try change levels or flatten the list
put a flatten node between the not node and the && Node
Thats strange. I have the same thing right above this that I copied it from and that one is working. I changed the level and its working. I should have been able to catch that.
Thanks,
