Does anyone has used this package?
Download and install the “EnergyPredictML” from http://dynamopackages.com.
Once installed, in this folder (with your user name)…
C:\Users<user>\AppData\Roaming\Dynamo\Dynamo Core\1.2\packages\EnergyPredictML\extra
You’ll find a PDF paper with a brief explanation of how the node works and an example graph that uses it:
Are you able to handle it and work with it?!
