Hello there!
I’m working on a solution that can make dynamo write to a door-parameter based on a boolean parameter value from its host wall.
My problem is that if the boolean in revit is left neither yes or no, it appear as nothing in my list i dynamo. If I try to use the value from the walls for the door parameter, dynamo runs the file but with warnings.
Are there a way to fill in empty lines with ex. zero?
