"Embed image" works only for "Live mode"?
hey all, I’ve two part question:
1- I am exporting some data to excel, then i want to write an image to that excel sheet. The problem is that the excel file doesn’t want to be accessed by two node at the same time. is there a node which tell the script to work out write excel node first and then Embed image node?!
2- there is an issue with “Embed image” node. It works fine with no path file node in it i.e. Live mode. But as soon as I feed it with file path node, it stops working, what’s the issue?
try a passthrough node (clockwork) or a wait/await node (orchid)
or even a code block with
[passthrough,waitfor][0]
to tell your script to edit excel first step then the second one
thanks for your reply.
but I don’t understand how to use it, is it the right way?!
Maybe something in this can help.
thanks simon for the link but that topic is regarding posting pictures from revit library, and I am importing a picture from my PC system :confused:
@uaftab.cem19
It works this way.
