Eliminate part of name
Hello everyone,
I have list of elements with names: A_0000_B_C. How I can eliminate _0000 and get just A_B_C?
HI @Gytis_Jurgelevicius
You can use string.replace node, as you see below.
Thank you @Mohammad_Nawar
It can be solution, but sometimes 0000 isnt constant and I don’t know how to eliminate 0000 in any case :confused:
if you show me your dyn, maybe I can help u
@Mohammad_Nawar
I just want to create views in Revit project browser from existing levels. Name must be made from level name (S_SL17_0_01S) and name of view group (e.g.: floor plans) Result: S_SL17_0_01S_Floor plans. But in this situation I don’t need SL17 and I want to get S_0_01S_Floor plans
I attached my printscreen:
Hi @Gytis_Jurgelevicius
@Mohammad_Nawar solution is not quite right. It added an extra “_” symbol. I suggest you use another approach.
@Kulkul
it’s not adding extra symbol :slight_smile: , I just didn’t put it inside the code block, to remove the underscore “0000_”
@Mohammad_Nawar It seems you have forgotten to add :grinning:
Thanks @Mohammad_Nawar @Kulkul
Its works perfectly :slight_smile:
