I am getting an warning message each time I re-open my dynamo file. Along with the error message, a second output appears in the node and automatically links the node. I then need to remove the node, add the node back in, and relink it. Why is this happening?
The warning message says:
"Warning: Dictionary.By.KeysValues operation failed. An element with the same key but a different value already exists. Key: ViewType.
I downloaded the latest version of Bakery as it had nodes that I needed. Bakery automatically installed all the packages seen in the image below, including archi-lab.net. When I installed Bakery I actually had to uninstall the archilab.net package first as Bakery had it and it conflicted. Do you think if I uninstall Archilab and reinstall it now that Bakery is installed that it will be stand alone and not conflict?
You’re using a very old version of archilab (Revit 2016 with Dynamo 1.X).
So uninstall archi-lab and reinstall it with a version running with Dynamo 2.X.
