Element to Space in linked model
Dear All,
I was trying to get the space name/number from a linked space model inside a revit model containing elements and families.
So, the script should give space information respective to families fed as inputs.
I’ve tried doing it using Genius Loci package but not sure what’s going wrong.
It would be great if anyone can help.
Thanks in advance.
Regards,
Atharva Purohit
you tried to send it a list rather than an element (input is a var:[]..[])
cordially
christian.stan
Hi probably something could work…
Hi Christian,
Not sure if I got your point.
Thanks,
Hi Soren,
Thanks, will try it right away and get back.
A bit skeptical about the bigger model, though.
Regards,
Atharva Purohit
I was trying to tell you this (But not sure the outcome either)
Cordially
christian.stan
Hi all,
It worked. My mistake was I was putting linked model instance as list.
Thank you for responding!
Regards,
Atharva Purohit.
