Could you help to find a solution for the Error?
It was working perfectly on Revit 2016
Error on Revit 2017
Thanks kulkul for your reply.
Working @MEP side
Just need to get the elements in the Space. Write the space info to the Elements.
It was working @2016
After you get the names use “Element.SetParameter” node to set the space names to your data devices. Does that make Sense!
I can’t find Element.Space
