Element issue (Dereferencing a non-pointer)
Hy everyone !
someone it´s having this problem with design script Element?
I´m using thins scrit with a shorcut in keyboard to type faster element get param. But it seems there is an issue with the element refx…
Dynamo version
thanks !
I don’t know what exactly causes the error but why are you doing this in a code block?
Just use this:
Hi @dca,
Multiple definitions for ‘Element’ can be found so the correct syntax is : Revit.Elements.Element.GetParameterValueByName(x, "View Name");
Off course @Daan!
Im doing this meanwhile , but i´m quite interested in know the issue in desing script.
It´s easy for me type a shortcut in my keyboard with the script. And better use one node instead two…
Thanks @Alban_de_Chasteigner!!!
works perfect! :grinning:
