Hi All,
I’m using the BIMorphs node element.intersectselement. But when i pass information into it i get a dereferencing a non-pointer error.
What could i be doing wrong ?
Hi All,
Please post a screenshot of the graph with the input/output previews of the local nodes shown. Hard to help without seeing the input/list structure output.
Interesting, I can pass empty lists into the bimorphs node just fine. A null input also produces a different warning entirely. I’d need to see an example where you’re actually getting the error to get a better understanding. It may also be a versioning difference.
Also, the List.IsEmpty check on your Generic Models should only be producing a single value due to the list level, and messes up the list filter. I’m assuming that’s a holdover from when you had additional categories in SetA.
Please provide an update with the following:
Without that info, anyone helping you is not able to do so as effectively.
