Hi, I was trying to get intersection of elements using Bimoprh, but for some reason it is showing mistake although when I check if the elements are supported, it shows they are. Has anyone encountered similiar problem? ![]()
It shows Element.IntersectsElement operation failed. Method not found: ‘Int64 . Revit.Elemen.Element.get_id()’
Hello @a.djukic333 and welcome here…bimorph is just updated for 2024 and works, so install the latest version and should work
It is working. Thank you ![]()
