Element (ID) from a surface
Hey,
is it possible to get the Element of a surface? For example when I pick “Select Face” the ID of the element is written in there, but I do not know how to extract it…
grafik
thx
interesting question.
I can’t see an obvious way (to get the parent elementID from a face of that element), although you’d think it must be possible as the node displays it
Being lazy, I’d probably work around it by using a select element node rather than a select face
Hello
the output of OOTB node ‘Select Face’ is a geometry surface, the reference is missing
an alternative with the RevitAPIUI
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import *
# Import ToProtoType, ToRevitType geometry conversion extension methods
TaskDialog.Show('Selection','Select a face')
ref = uidoc.Selection.PickObject(ObjectType.Face, 'select a face')
elemId = ref.ElementId
element = doc.GetElement(ref.ElementId)
dynSurface = doc.GetElement(ref).GetGeometryObjectFromReference(ref).ToProtoType()
OUT = elemId, element, dynSurface
This works perfect. I am a real begginer in Python, but looks like I should learn more about it
thank you
It’s so nice @c.poupin !!! Is there any way for multiple faces? Thanks
@brenofilipe Please start new topic. This topic has already solution.
