Yeah, I am uncertain of the outputs from this node, I believe it may be a vector describing the element’s rotation vs the world XY plane.
My goal is to generate “front” elevations of Curtain Wall assemblies. (Storefront) I am working in a new office that has projects with many pieces of curtain wall that must be elevated in the documents.
I have run into a bit of a problem with rotating the assembly origin of multiple assemblies. I would like to be able to feed in a list of curtain wall assemblies & have their origins all rotated so that selecting a “front” elevation will produce the desired result.
I don’t know where it is from, but I can have that node coded tomorrow at some time… I am running tests on a range of new nodes I am going to release tomorrow. A node for orientation can be fixed together with these…
I have released an update of Orchid with +20 new nodes, among these, is this node…
if you think it should work differently, then please give me some feedback
