Element get location from linked model
Hello everyone,
i am trying to get element location from linked model, but it placed far from the model. i realized it is due to internal origin mismatch, but i dont know how to solve it. if anyone knows about it please help me. thanks in advance
apply an additional transform. u get that from the link instance itself if remember correctly. also, i believe there are some utility nodes from a package called bimorph that handle this.
bimorph None will do the work.
Bimorph nodes v2.2 adds holistic support for linked-element clash detection with new LinkElement nodes - Packages - Dynamo
things might change over the years, but i believe bimorph was the go-to option for such a problem.
thanks for your replay. but here it gives me error waring. dont know the rason.can you please look into it. thank you very much.
why are you all focusing on copy to active document? is that what you really after?
try some think like this.
Copy links.dyn (10.4 KB)
Thanks. actually i am a beginner in this field. i tried your script, it copy the elements from the model, but i want only location. finally i translate geometry and i got the location. i really apricate your effort and once again thank you very much.
I’m glad it worked!
