Hey all,
For a project I need to index some elements.
All the elements are from the same type and family.
I need to edit the properties and fill in a number and count up 1 per element.
Example:
Brick 1: comment 1 //Locate commentsection enter number 1
Brick 2: comment 2 //Locate commentsection enter number 2
Brick 3: comment 3 //Locate commentsection enter number 3
This needs to be done in the properties menu.
Now I wanted to automate this with Dynamo.
Because I want to learn Dynamo better and I dont want to manually type a couple 100 numbers.
So I made a script.
It works with writing input to the properties.
The only problem is that it writes the same value to every element.
So I thought I could put the value in like this:
0…20…1
0= 1st brick
20= last brick
1= steps of value
But Dynamo doesnt accepts list as an value.
The scriptAdd info in paramters for selection.dyn (33.5 KB)
Cheers
