I’m encountering an issue with assigning sequential values to a parameter for multiple elements. Here’s the situation:
- I have two lists:
- List 1: Contains 278 door elements from the Revit model.
- List 2: Contains 278 names (text values) that I want to assign sequentially to the “Comments” parameter of the doors.
- I’m using the
Element.SetParameterByNamenode with the “Lacing” set to Longest, expecting each value from List 2 to be assigned to the corresponding door in List 1.
The problem: Instead of assigning the values sequentially (e.g., Name 1 to Door 1, Name 2 to Door 2, etc.), Dynamo assigns the same value (the first value from List 2) to all the doors in List 1.
What I expect: Each door should get a unique value from List 2 in the same order as they appear in the lists.
Has anyone experienced a similar issue or knows how to correctly map the values so that they are applied sequentially to each element? I would appreciate any suggestions or guidance!
List1:
List2:
After running the script, all doors receive the same value in the “Comments” parameter instead of getting unique values from the list.:
Thank you in advance!
