Hi all,
Still new and struggling to find the right method for this, but I’m wondering if I can edit the Insulation Thickness parameter of pipes based on the size of the pipes.
So ideally I’d want pipe by service > check size > if below 65ø 25mm thickness > if above 65ø 40mm thickness
I’m also getting errors saying this parameter is read only. Is there a way around this?
