The Dynamo Node i have now is expecting xlsx file. you will have to specify the sheet that you want within that xlsx file.
Hi, did you forgot to attach the code?
or shall i use the Old code?
I did it forget.
But I think each of my attachments has 2 files in it.
If not let me know and I can fix it later in the day.
Please, mark the question as answered
Done marking it as solution. Kindly share the Dyn file so I can test the excel method. Thank you
Dear Awilliams,
Thanks for post. Worked fine at the not used family.
However, not changing formula in the family which already used in the project file. Any recommendation?
Thanks.
