I just had a look at the Python code within the DanEDU.FamilyDocument.SetFormulaByName node, and it converts the values into strings so inputting a null value doesn’t seem to work. If you paste this into a Python script node, it will accept a null value (removed the quotes around values[idx] in line 39)
#Copyright(c) 2014-2017, DanEDU Dynamo
#Erik Falck Jørgensen, Technical University of Denmark (DTU)
from Autodesk.Revit.DB import*
app = uiapp.Application
#log builder, only for testing
#log = []
#input assigned the IN variable
docs = IN[0]
params = IN[1]
values = IN[2]
#wrap input inside a list (if not a list)
if not isinstance(docs, list): docs = [docs]
if not isinstance(params, list): params = [params]
if not isinstance(values, list): values = [values]
#default document set to DocumentManager.Instance.CurrentDBDocument
if docs[0] == 'Current.Document':
docs = [DocumentManager.Instance.CurrentDBDocument]
else: pass
#core data processing
for doc in docs:
try:
for idx, item in enumerate(params):
param = doc.FamilyManager.get_Parameter(item)
doc.FamilyManager.SetFormula(param, values[idx])
log = 'Formula set successfully'
#only for testing
#log.append('Formula set successfully')
except:
log = 'An error occurred! Please veryfy setting'
#only for testing
#log.append('An error occurred! Please veryfy setting')
#output assigned the OUT variable
OUT = docs, log
This works on my end:
