I am using the Schedule Formatting node from Archi-Lab. My goal is to edit the column width of 5 parameters from a schedule at the same time (not having to change the code for each parameter). I have gotten the node to work for changing only one parameter column’s width, but I can’t seem to get it to work for multiple. Each parameter will be changed to the same column width.
I have done this:
Here is my code:
experimentdec4.dyn (13.4 KB)
