Hi forum!
I am working on a script for collision-check between elements in Revit. E.g. walls and ducts. To make it even more visible in Revit then the tickbox, is there a way to color the sharedparameter box with another color than standard white, through Dynamo?
Edit: Don´t mind the Category dropdown menu is on Pipes…
Input and help are appreciated!
Have a nice day!
You can use colours for schedule cells background, like in Excel, but I don’t think you can change the background colour of the properties palette.
Thank you for your answer @lucamanzoni. I know the schedule can be colored, but was hoping for some kind of Revit/Dynamo hack to color the mentioned box(es).
It is easier to see e.g. a yellow box, rather than a checked box.
If you can set the parameter to an unused group, at least it is separated out
I am creating SharedParameter with Dynamo, so was hoping for coloring the box within the .dyn script.
