Has anyone used the DynaSpace package? I tried the official case, but the package version does not match. Has anyone successfully run the case in the following web?
https://dynamobim.org/space-planning-in-dynamo-with-dynaspace/
I have. Where is your error? Have you installed the latest version of the package?
I have installed the DynaShape_0.6.2.0 package, but it is not compatible with the version in the case.
It looks like you missed some steps on the installation. Did you follow them closely? Likely the dlls are blocked, usually a result of using the built in zip tools which come with windows instead of 7zip.
My problem has been solved, thank you very much.
