My new Package (http://image.prntscr.com/image/0e82970d604c44738685278f4e3d448b.png)
Could you explain what it does. I’m looking for a way to push id from excel to AutoCAD blocks.
This is the first version of the package. It has only four nodes: points import, lines import, build the point, build the line. You can solve your problem. I need to do a little bit of time.
I just downloaded the Flux plug in. Thank you John.
Is there a webpage with examples of its use?
@Khasan_Mamaev nice! In case there’s any Dynamo users who aren’t AutoCAD users or do not have access to it, I’ve created a package called bimorphNodes to achieve the same layer filtering from a DWG or DGN using bimorph.CurvesFromCADLayers
. All bases covered!
Nice, Can you make a node to read points/ line coords out of a CAD file into Excel?
EATTEXT command in autocad does that with a pretty nice user interface
You can use DataExtraction command in Autocad
Very good!
