So, an interoperability project plug-in I am trying to create a set of nodes which have a button on them. The idea is that, when the user presses the button, a windows form pops-up and you can select your desired output and press “Ok”. Next the nodes should return what you have selected. I am now stuck on the point where I can press the button and the form pops-up, but when I press “Ok” the node only returns “null” which is the default value.
Because I am using 3 classes (The Node class, the Customization class and the XAML) I don’t know what to assign where to let it function.
Below are the classes for the Node and the Node Customization
using System.Collections.Generic;
using Dynamo.Graph.Nodes;
using Dynamo.Controls;
using Dynamo.Wpf;
using Autodesk.DesignScript.Runtime;
using ProtoCore.AST.AssociativeAST;
namespace Dolly_for_Dynamo.Nodes
/// <summary>
/// This is the "Select Project" Node. It is a Class which inherits from the Node Model Base Class.
/// </summary>
[NodeName("Select Project")]
[NodeDescription("Select the Project Directory which contains the Json files")]
[OutPortNames("Project")]
[OutPortTypes("string")]
[OutPortDescriptions("The project directory")]
[IsDesignScriptCompatible]
public class ProjectSelector : NodeModel
//The Public constructor
public ProjectSelector()
RegisterAllPorts();
//The Private property of the Class which represents the Output
private string _outputPath;
//The Public property of the Class which represents the Output
public string OutputPath
get
return _outputPath;
set
_outputPath = value;
RaisePropertyChanged("OutputPath");
OnNodeModified(false);
//The Public class methode to execute a function and get an output
public IEnumerable<AssociativeNode> BuildOutputAst()
if (this.OutputPath != null)
return new[] { AstFactory.BuildAssignment(GetAstIdentifierForOutputIndex(0), AstFactory.BuildStringNode(this.OutputPath)) };
else
return new[] { AstFactory.BuildAssignment(GetAstIdentifierForOutputIndex(0), AstFactory.BuildNullNode()) };
/// <summary>
/// Node Customization Class. This will parse the UI for the ProjectSelector Class on the Node model
/// </summary>
[IsVisibleInDynamoLibrary(false)]
class ProjectSelectorNodeView : INodeViewCustomization<ProjectSelector>
public string OutputPath { get; set; }
public void CustomizeView(ProjectSelector model, NodeView nodeView)
ProjectSelectorControls ui = new ProjectSelectorControls();
model.OutputPath = ui.outputPath;
nodeView.inputGrid.Children.Add(ui);
ui.DataContext = model;
public void Dispose()
And this is the XAML code so far
<UserControl x:Class="Dolly_for_Dynamo.Nodes.ProjectSelectorControls"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:local="clr-namespace:Dolly_for_Dynamo.Nodes"
mc:Ignorable="d" Height="57.899" Width="186.259">
<Grid HorizontalAlignment="Right" Width="154" Height="58" VerticalAlignment="Top" Margin="0,0,32.4,-0.4">
<Grid.RowDefinitions>
<RowDefinition Height="54*"/>
<RowDefinition Height="7*"/>
</Grid.RowDefinitions>
<Button
Margin="0,0,33,17.6"
Click="Button_Click"
Content="Select Project"
IsEnabled="True" BorderBrush="{x:Null}" Background="White" Foreground="Black"
</Grid>
</UserControl>
With the Code behind it
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Forms;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Dolly_for_Dynamo.Functions;
/// <summary>
/// Interaction logic for ProjectSelectorControls.xaml
/// </summary>
public partial class ProjectSelectorControls : System.Windows.Controls.UserControl
public string outputPath { get; set; }
public ProjectSelectorControls()
InitializeComponent();
private void Button_Click(object sender, RoutedEventArgs e)
FolderBrowserDialog browser = new FolderBrowserDialog();
if ((browser.ShowDialog() == DialogResult.OK))
//Harvest values from form and assign them to local variables
outputPath = browser.SelectedPath;
System.Windows.MessageBox.Show(outputPath);
My question is what do I have to change to assign the FolderBrowserDialog.SelectedPath from the XAML to the ProjectSelector.OutputPath?
Thanks in advance
