Dynamo Workflow to Automatically Set Surface Elevation Analysis Ranges
Hi everyone, I need some help.
Is there a way (possibly using Dynamo) to automate surface elevation banding for a Grade Test Surface?
Right now, my workflow is repetitive. Every time I select my surface and switch it to the Grade Test Surface style, I still have to manually go to the Analysis tab and re-enter the elevation ranges and colors.
What I would like is for this to be automatic:
  • I have 8 analysis ranges.
  • Cut should always display in shades of red.
  • Fill should always display in shades of green.
Example for the cut ranges:
  • ID1: Min −5" to Max −1.25" → Color 16
  • ID2: −1.25" to −1.00" → Color 14
  • ID3: −1.00" to −0.75" → Color 12
  • ID4: −0.75" to −0.50" → Color 10
I’ve attached a screenshot showing the desired result. Currently I have to re-enter these settings every time, which is very repetitive.
Hi @f.concepcionUE5JP ,
The Surface.ElevationAnalysis node from the Camber package that can create surface elevation banding. I have not tried it with a Grade Test Surface, but it works for a terrain surface.
Also, I created 2 versions of the list of ranges and colours: 1 simple method and 1 method that has a more intuitive input for the user.
C3D_SurfaceAnalysisRanges.dyn (37.2 KB)
Hi @ISECnico, thank you very much for this! I gave it a try, adjusted a few minor details, and it worked perfectly. Super love it. Thanks again!
