This is my lesson, which solves the problem of interaction between Dynamo and AutoCAD. Lesson in Russian, but it is understandable
Python code:
clr.AddReferenceToFileAndPath(‘C:\Program Files\Autodesk\AutoCAD 2015\Autodesk.AutoCAD.Interop’)
from Autodesk.AutoCAD.Interop import *
from System import *
restart = IN[0]
curves = IN[1]
acadApp = AcadApplicationClass()
acadApp.Visible = True
for i in (curves):
p1 = i.StartPoint
p2 = i.EndPoint
p1C = Array[float]([p1.X, p1.Y, p1.Z])
p2C = Array[float]([p2.X, p2.Y, p2.Z])
lin = acadApp.ActiveDocument.Database.ModelSpace.AddLine(p1C, p2C);
acadApp.ZoomExtents();
This is really great! Commands are from ObjectARX, right?
yes
FEM Mesh in AutoCAD
how can I make the reverse process, look for an entity in AutoCAD and send to Dynamo
acadApp.ActiveDocument.Utility.GetEntity(object, object, object)
Excuse me please, but I do not know how to do it. I am currently engaged in this task. On the results of write here
