I need to push the Topography generated in dynamo from points to revit, can anyone help me with this
Did you use Topography.ByPoints Node?
yes , i used that node to create a topography. But it is not visible in Revit.
Check your visibility options or check the view ranges. Are sure that you used right points? Dynamo uses internal points if you have coordinates in world coordinates.
Check your units
Thanks , it worked.
