Hi all
I am a novice user, and after help on the following, please if anyone has a script or guidance.
I am after some advice or a potential workflow on how to perform this within Dynamo.
I am looking for a way to load families from several different locations to our project when out of date with just one click of a button. Possibly using an excel file with each file path to be reloaded, then load these in using import. Excel.
Do we know how this can be done or advise?
Example
Structural Columns
R:\Revit\Design Data\Families\Structural Column\Cripple 01.rfa
R:\Revit\Design Data\Families\Structural Column\Willerby_Standard_Agnes_Rip_R18.rfa
Structural Framing
R:\Revit\Design Data\Families\Structural Framing\SheathingPanel.rfa
R:\Revit\Design Data\Families\Structural Framing\Square Cut Agnes Board.rfa
R:\Revit\Design Data\Families\Structural Framing\Willerby_Agnes_Panel_Horizontal.rfa
R:\Revit\Design Data\Families\Structural Framing\Willerby_Agnes_Track.rfa
Yes, it can be done. There are a couple custom packages out there that allow you to load families, such as Clockwork document.loadfamily and others that can pull lists from excel.
Workflow is you need to:
- Get the excel workbook/spreadsheet (preloaded with info)
- Get the worksheet (you might need DataShapes or archi-lab here)
- Get file names and paths from the worksheet
- Send it to Clockwork’s document.loadfamily node
hi @dclunie,
I already made this script, please check this: load_families_excel.dyn (15.9 KB)
here is the dynamo script content:
here is the excel format:
cheers!
-biboy
Hi Thanks
For this it is great. I am having an issue with the Python node at the end please see screenshots.
Can you advise on what to do? I did assume it may be because I did not have Bumblebee installed?
hi @dclunie
add this add the very top of the python script.
import sys
sys.path.append(r"C:\Program Files (x86)\IronPython 2.7\Lib")
-biboy
Hi
As a matter of interest, can this method be used to fire Independent dynamo rules in sequence?
I have 5 rules which the guys need to run in order, and sometimes we have users not selecting certain rules. This could be a way of one rule to run all.
Master rule
- Rule 01
- Rule 02
- Rule 03
Hi @dclunie,
Can you explain further what your rules are? Nobody would understand if you just say Rule 1, Rule 2, Rule 3 etc.
-biboy
Yes, I can relay a bit further on this. I have several rules, and each of them provides different functions and have been made as separate rules to validate the products we produce in a mass manufacturing environment. The cad reseller developed them separately as they compiled information from many different families writing metadata back to parts if certain condition = true.
For instance, the engineer must select each time when editing a project to ensure data is validated correctly before we release it. Sometimes, errors are slipping via the net because of engineer manual intervention.
01_Oslo Board check
02_Production_Information
04_Bevel to Timber (DESC2)
05_OSB3 Board Check
I want 1 rule called Validation that runs the rules shown above in one click?
Hopes this helps
hi @dclunie
your explanation I think is a bit off for me to understand what you want to do.
please explain the difference between the rules and and how are they related to the files
in the excel.
-biboy
Hi blsalvio
If possible if the address of the dynamo rule was stored in the xls file could it then work like loading in families.
Find each rule and run. Im not entirely sure if this can be done.
Thanks for your help.
hi @dclunie
please check this: load_families_excel.dyn (22.5 KB)
Excel format:
Dynamo input:
-biboy
I was looking for a python code to load families with override options, but this one seems not to be working on python 3?
thank you
