Dynamo surface vs. Revit Surface - node: RevitFaceReference.FromDynamoSurface
Hi all,
can somebody explain to me why there’s any difference between a surface created in dynamo and a surface selected from Revit. Its both a surface, right?
I’m using a node from clockwork ‘RevitFaceReference.FromDynamoSurface’. My surfaces created in dynamo gives me ‘null’ and faces selected from Revit a reference as expected.
Thanks in advance!!
RevitFaceReference.FromDynamoSurface will only return a RevitFaceReference if there is a Revit face underlying the Dynamo surface, not if the Dynamo surface has been created independently:
@Thomas_Corrie, clear, thanks
