Dynamo: Structure part properties material
Hello to everyone
Does anyone know which node I must use to change the material field in the structure properties. to a user defined material?
Annotation 2023-08-17 105059
Hi @dsacotokaczmarek
Possible to share dwg file here?
Which Civil3D version you’re using?
Hi @Kulkul,
Since there was no respond I was experimenting a little bit and came with the solution. i will post the solution so maybe like this I can help someone. I was using the proper node all the time (image below). the only thing wrong in it it was the name. I had to type “Mat” instead of “Material”
Thanks anyway for the will to help
