Hello, I would like to fill in a parameter according to a specific data in another parameter.
How to do it please
?Change the index to a number. Currently by putting “” around them you’re making it into a string.
I don’t think the List.Transpose is doing anything either.
I change the number but there isn’t good.
Makes sense actually.
There’s another mistake, you’re not actually inputting an element into Element.SetParameterByName but rather, the value you’re getting from earlier.
You’re using String.Contains, which isn’t used to figure out wether there’s a certain string in a list but rather if a string contains contains a specific substring. For example, you could filter this one out on which strings in that list contain “T2”
Use List.Contains instead.
It’s ok i find the solution thanks a lot. My node is ok, i must do close and open again dynamo and it will be ok.
