Is there a Dynamo script that will bind all Revit links?
Your advice is appreciated.
Hey Steven, not that I know of. In searching the revit forums it looks to potentially still be flagged as a Revit idea suggestion which tends to mean it’s not in the API:
Usually UI related commands (bind, insert drafting views, copy monitor) are often outside API coverage. They may have postable commands but they’re generally very limited in functionality.
Looks like the idea hasn’t gained much traction:
RE the motivation behind binding, if it is speed versus doing it the manual way, unfortunately it would be just as slow if not slower would it be possible. The only tedium it would avoid is being able to set it to bind multiple, walk away and return later.
Even if there’s a method in API to do that, the elements binded in the project are not appearing in same location there’s a Revit glitch on height not resolved
