Dynamo script run time and memory (32GB/64GB RAM)
Hello Dynamo Friends :slight_smile:
I upgraded from 32GB to 64GB RAM and compared the speed with a benchmark tool and with Dynamo.
Benchmark tool says RAM is now 10% slower.
Dynamo runtime is now 10% longer (tested on a script that runs 30 minutes).
So I´m a little confused because I was hoping for faster runtimes. I had in mind that it´s pretty much a linear correlation between runtime and RAM but i don´t know if i have this wisdom from own experience from years ago or just read it somewhere on the internet…
Our IT guy say this was expected because more RAM does not make anything faster, you can just run more programs at the same time. On The Benchmark Test I´m 0 from 100, that´s far from OK.
How is your experience?
Well, you can have just one problem with memory. If you have too small amount of it and it overflows. Did you try to run from Dynamo player?
No my tests were not done with dynamo player, I can try that also.
I upgraded because RAM was running on 99% during dynamo runs, thats why I expected improvement.
Edit:
Oh and now with 64GB RAM is running constant on 50%
Can someone with 64gb test if he uses more then 50% when running dynamo?
You need to make sure it is exactly the same benchmarking otherwise the output is flawed. This means same versions/build of revit and dynamo, same amount of packages and exactly the same files utilised within the test process.
For example using dynamo 2.10 on the 32gb and then using 2.0.4 on the 64gb is not a good way to test because later versions have performance enhancements.
The type of ram from channel and timings can effect things speed.
Interesting, while i don’t know 100% how Revit and or Dynamo use memory and if i’m honest i haven’t found the silver bullet for the direction of what the big hitters are for hardware build perfection, you may want to check the following basics and reporting these to the forum.
-Speed of previous ram & New ram (mhz)?
-CAS Latency of previous & New ram (CL)?
-Motherboard Model
Some things to consider about your build before considering this a Dynamo Problem
*Check that your motherboard can handle the new rams mhz else it will be bottlenecking and just running at the slower speed.
*Open the task manager and check that the speed of the Ram matches what you are expecting, if it is not then you may need to enable XMP on the motherboard.
Not just the same versions, graph, and file. But the same background processes running (meaning quit everything else you can). Even the. You are certain to not get the same value(s), so you also need to compare the values of multiple runs (comparing the min, max, median, and mean over the course of a dozen or so tests) at multiple points in time.
Basically benchmarking requires either automation to do the runs (ie: journal playback), or some form of tool to recreate exact conditions at the same time…
This post can help with the former. For the later…
OK, so first the problem were the used slots for RAM. 1+3 did´t work properly, 1+2 works now as expected, I´m now getting the double GB/s on multicore processing so everything is fine.
This was the result when using slots 1+3:
So with high expectations back to dynamo testing. I´m for sure testing the same graph with same Revit and Dynamo versions. The results are pretty much equal at milliseconds, so the test setting is not a problem.
Result: Still 10 % slower with 64GB RAM.
Looking in the taskmanager I can see only 10GB are used by revit, this number increases by about 500mb/minute but without effecting the performance.
Only difference between the old and new RAM is that the old one was dual rank and the new ones are single rank. The machine is a HP z book, there are no bios settings regarding RAM, like XMP.
So I would say that revit/dynamo just can´t use more memory or doesn´t need more memory, so more memory has no effect.
Not quite - the new RAM is clocked at different speeds even in the content which you’re showing. Likely other aspects will differe, but we’ll digress pretty quickly.
Revit has a system cap in terms of the amount of memory it can use, both by it’s installation and by Windows. As you are in a Dynamo for Revit environment, Revt will control the resources available 100% of the time. And so what you want to test is Revit, ignore the Dynamo aspect for a bit. The Revit Forum would be where I recommend you start exploring such testing. Alternatively you could test Dynamo Core, as that would be a bit more consistent in terms of performance (lighter application, no worksharing operations, less internet connectivity to slow things down, won’t default to utilizing a the HDD for scratch disc/element expansion, etc.).
revit forum also have a benchmark tool that may be useful in this case.
https://www.revitforum.org/forum/revit-all-flavors/hardware-and-infrastructure/36875-rfo-benchmark-v3
Wow, awesome tool.
Did tests with 32GB and 64GB, at this benchmark the 64GB setup performs better!
So Revit gets faster but Dynamo gets slower with more RAM…
32GB
RVT 2023 - Full_Standard set - 2023.11.09 @ 21.43.19 on AT-5CG3130K2N.txt
    RFO Benchmark v3.3 (build 09.05.2023)
    RevitForum.org
All times are in seconds, lower is better.
Run on Revit 2023.1.1
_________________________________________________________________
Update
    8.46   update previous version file
Model creation benchmark
    5.64   opening and loading the custom template
   11.42   creating the floors levels and grids
   12.98   creating a group of walls and doors
   19.49   modifying the group by adding a curtain wall
    8.41   creating the exterior curtain wall
    6.23   creating the sections
    2.61   changing the curtain wall panel type
   10.80   creating area plans
    2.19   creating and applying view template
   79.77   TOTAL
Export benchmark
   40.52   export all views as PNGs at 300 dpi
   38.45   export all views as DWFs
   74.10   export all views as DWGs
   35.49   print all views as vector *
   62.15   print all views as raster *
Notes:
 *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
Render benchmark
   44.33   render
Graphics - Standard View
    5.93   activate View Styles view
    0.32   change view to Wireframe
    0.50   change view to Hidden
    0.59   change view to Shaded
    0.60   change view to Consistent Colors
    3.35   change view to Realistic
    0.54   refresh Wireframe Line view x10
    1.86   refresh Hidden Line view x10
    1.92   refresh Shaded view x10
    1.87   refresh Consistent Colors view x10
    2.03   refresh Realistic view x10
    0.25   activate View Cube view
    1.67   rotate view x1
   21.43   TOTAL
Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
TEST CONDITIONS:
Mfr:   HP
Model: HP ZBook Fury 16 G9 Mobile Workstation PC
OS:    Microsoft Windows 10 Enterprise 64-bit (build 2009)
CPU0: 12th Gen Intel(R) Core(TM) i7-12850HX
Max Clock Speed: 2.1Ghz
Physical Processors: 16
Logical Processors: 24
Total Physical Memory: 32GB
Controller0ChannelADimm0: 32GB @ 4800Mhz
Graphics Card: Intel(R) UHD Graphics
Graphics RAM: 1GB
Driver version: 30.0.101.1631
Screen Resolution: 1920 x 1200 x bit @ 60Hz (max 60Hz)
DPI Scaling: 125%
Drive Type: Local Disk (NTFS)
Drive Model: MTFDKBA1T0TFH-1BC1AABHA
RAW DATA:
    8.984    7.930    8.477   update previous version file
    5.672    5.609    5.648   opening and loading the custom template
   11.188   11.336   11.750   creating the floors levels and grids
   12.609   12.750   13.586   creating a group of walls and doors
   18.672   19.836   19.977   modifying the group by adding a curtain wall
    8.312    8.336    8.594   creating the exterior curtain wall
    6.094    6.297    6.297   creating the sections
    2.711    2.453    2.680   changing the curtain wall panel type
   10.570   10.836   11.008   creating area plans
    1.633    1.984    2.945   creating and applying view template
   40.383   40.625   40.539   export all views as PNGs at 300 dpi
   39.914   37.719   37.727   export all views as DWFs
   73.250   72.867   76.172   export all views as DWGs
   35.492   35.375   35.609   print all views as vector
   61.914   62.203   62.320   print all views as raster
   53.641   39.797   39.562   render
    5.969    5.992    5.828   activate View Styles view
    0.320    0.305    0.320   change view to Wireframe
    0.516    0.500    0.484   change view to Hidden
    0.609    0.586    0.586   change view to Shaded
    0.602    0.586    0.617   change view to Consistent Colors
    3.305    3.422    3.320   change view to Realistic
    0.555    0.523    0.531   refresh Wireframe Line view x10
    1.875    1.844    1.859   refresh Hidden Line view x10
    1.938    1.914    1.914   refresh Shaded view x10
    1.867    1.898    1.852   refresh Consistent Colors view x10
    2.219    1.930    1.953   refresh Realistic view x10
    0.250    0.242    0.250   activate View Cube view
    1.688    1.672    1.664   rotate view x1
64GB
RVT 2023 - Full_Standard set - 2023.11.09 @ 19.12.52 on AT-5CG3130K2N.txt
    RevitForum.org
Update
    8.28   update previous version file
    5.57   opening and loading the custom template
   10.28   creating the floors levels and grids
   12.00   creating a group of walls and doors
   18.68   modifying the group by adding a curtain wall
    7.20   creating the exterior curtain wall
    5.93   creating the sections
    2.35   changing the curtain wall panel type
    9.58   creating area plans
    1.38   creating and applying view template
   72.97   TOTAL
Export benchmark
   40.32   export all views as PNGs at 300 dpi
   37.11   export all views as DWFs
   72.70   export all views as DWGs
   35.32   print all views as vector *
   61.58   print all views as raster *
Notes:
Render benchmark
   41.14   render
    5.74   activate View Styles view
    0.49   change view to Hidden
    0.59   change view to Consistent Colors
    3.27   change view to Realistic
    0.52   refresh Wireframe Line view x10
    1.83   refresh Hidden Line view x10
    1.88   refresh Shaded view x10
    1.83   refresh Consistent Colors view x10
    2.18   refresh Realistic view x10
    0.24   activate View Cube view
    1.63   rotate view x1
   21.11   TOTAL
Notes:
TEST CONDITIONS:
Mfr:   HP
Total Physical Memory: 64GB
Controller1ChannelADimm1: 32GB @ 4800Mhz
Graphics RAM: 1GB
DPI Scaling: 125%
RAW DATA:
    9.008    8.008    7.828   update previous version file
    5.617    5.594    5.484   opening and loading the custom template
   10.406   10.273   10.164   creating the floors levels and grids
   12.000   12.078   11.922   creating a group of walls and doors
   18.656   18.617   18.773   modifying the group by adding a curtain wall
    7.273    7.164    7.148   creating the exterior curtain wall
    6.086    5.859    5.836   creating the sections
    2.328    2.344    2.367   changing the curtain wall panel type
    9.633    9.664    9.430   creating area plans
    1.430    1.344    1.367   creating and applying view template
   40.086   40.414   40.453   export all views as PNGs at 300 dpi
   37.086   37.297   36.945   export all views as DWFs
   72.641   73.000   72.445   export all views as DWGs
   35.266   35.477   35.203   print all views as vector
   61.703   61.211   61.828   print all views as raster
   39.633   39.469   44.312   render
    5.680    5.891    5.648   activate View Styles view
    0.328    0.320    0.312   change view to Wireframe
    0.492    0.492    0.500   change view to Hidden
    0.594    0.602    0.578   change view to Shaded
    0.586    0.594    0.602   change view to Consistent Colors
    3.320    3.234    3.266   change view to Realistic
    0.531    0.508    0.523   refresh Wireframe Line view x10
    1.828    1.836    1.828   refresh Hidden Line view x10
    1.875    1.883    1.883   refresh Shaded view x10
    1.828    1.828    1.828   refresh Consistent Colors view x10
    2.141    2.156    2.250   refresh Realistic view x10
    0.227    0.258    0.250   activate View Cube view
    1.633    1.617    1.641   rotate view x1
I can say with a reasonable degree of certainty this shouldn’t be the case. What graph are you testing?
